1 - 5 of 5 Posts
· Registered
Good day
I have a big accurate (it better be for $15) 45° drafting triangle.
To save it, I Copied and Past it to plywood triangle.
If you copy it to 1/2" or 3/4" and make 2 slots for clamps, you can use it as "square holder" during carcass, box or frame gluing
Happy New Year
niki
· Banned
A nice idea for home made glueing jigs. Rockler Woodworking has some small assembly squares made from a plastic that glue does not stick to. They make these in two sizes and have a new set that is angle adjustable. They call these jigs "Clamp its" and they also have special miniature F style clamps designed to fit them.
· Registered
Discussion Starter · #3 ·
Thank you Mike
When I made it, I did not mean to use it for gluing.
After I made it I thought that if I copy it to 1/2" or 3/4" and make slots for the clamps, it can be used also for gluing.
I forgot to mention that, in this case it's better to remove part of the apex, so it will not touch the glue squeeze-out at the carcass corner.
niki
· Registered User
· Registered
Discussion Starter · #5 ·
Hi Joe
The "leg" (Cathetus) is 32 cm (around 12½") and the long side (Hypotenuse) is 45 cm (around 18").
The thickness is 1/8" (3mm).
You can easily enlarge the triangle during "copying" on the router table.
If you want to be sure that the router bit cutter will not touch the plastic... when you screw the triangle to the plywood put some washers or spacers between the triangle and the plywood.
niki
1 - 5 of 5 Posts
