Hi Everyone !! My name is Eric and I am new to the site. This i my first post and I really need some help. I recently purchased a new slab oak veneer HC interior door for my downstairs bathroom. It is 28"x80"x1 3/8" - WxHxD respectively. My house is only 14 years old and this door needed replaced. The problem is this: The existing door and jamb is only 27 13/16"x80"x1 3/8". Essentially I am wanting to use my 1/4" shank straight bit and trim down 1/8" so the new door fits in the existing jamb. If I was to replace the jamb, I run into further issues with fixing framing, threshold repairs, etc. Is it possible to do so with a straight bit given the length of the bit is only 1" long. I think I would need to run the door through then flip it over to complete the other side. The test runs I have tried all have failed because it is not lining up and looks horrible. Any and all tips are appreciated and well taken. Thanks in advance.
Eric
Either get a longer bit, or use a circular saw with a decent blade (I would use a saw) .
Either way, you'll need a guide clamped to the new door. You can use anything that is straight (i.e. very straight) and will not interfere with the saw. You can buy an inexpesive 8ft long guide for $20 (usually comes in 2 pieces). If the old door has a straight side, you can use that for a guide.
Assuming the new door is straight, place one long edge of the old door against the a long edge new door. If there are no gaps, it's straight. If there are gaps (even small ones), try the other edge. Also, if using the hinge edge, make sure the mortices ar up - so the circular saw base will have a continuous edge to ride against. You may have to raise the saw slightly (i.e. reduce the cutting depth of the blade) so that the motor housing clears the old door (which would be clamped to the new door). Make sure everything will work before turrning on the power (i.e. dry run).
Also, rather you can use the old door as a pattern to mark the new door cut line to make sure you measured correctly and to check that the opening (jamb) is square. Often, older homes may have doors that have been modified (custom fit) to a jamb that wasn't square to begin with, or became out of square due to settling, expansion/contraction, etc. It would be a good ide to line up the hinge side of the old door with the hinge side of the new door and check the other 3 sides for squareness.
