A few months ago Amazon had a woodworking sale and I was able to pick up a new Triton TRA001 for $196.65 after tax and free Prime shipping. It's a popular router on this forum so I thought I'd post a few unboxing pictures of what you get with what was the North American package. It's not officially for sale at Amazon currently, likely due to a change in distributor from Kreg to Toolstream.
Later I'll post my initial Incra plate and Incra table installation.
The box was a bit beat up but there's plenty of styrofoam padding on the inside.
Specifications:
Contents: router, edge guide assembly, 1/4" and 1/2" collets, table height adjustment crank, collet wrench.
Here is the edge guide installed. It's held to the router base by 2 spring loaded bolts through the keyhole slots. Edge guide is adjustable via screw down clamps.
Router inverted showing where the table height adjustment clamp attaches to the fine adjustment knob.
Here is removal of the base plate for installation on a router table insert. Requires removal of four Philips head screws and the two edge guide attachment bolts. If you don't remove the bolts, then your plate will wobble on the underside of the router base. This got me confused for a while! :blink:
For table installation you will want to remove the plunger spring. The spring cap is held in place via a small Philips head screw. Twist the cap ever so slightly and it will jump like a jack-in-the-box... hold onto that cap or it will fly! Replace cap & retention screw once you remove the spring.
The router is now ready for installation on a router plate!
Specifications:
