Welcome to the forum.
I should further explain. I had the same issue. Have you tried to remove the router from the table and check to engage the collet pin. I had the same issue. When I removed the router from the table it worked fine. I carefully reinstalled the router in the table and it worked fine.Hi Lemmer,
If the on/off switch is locked in the "0n" position the router will not raise high enough to engage the pion.
I hope this helps. I learned this from having the same issue.
Bob
Hi all, firstly I noted I posted this thread under the wrong sub category as I did it on my mobile at first and didn't see - apologies.I should further explain. I had the same issue. Have you tried to remove the router from the table and check to engage the collet pin. I had the same issue. When I removed the router from the table it worked fine. I carefully reinstalled the router in the table and it worked fine.
If you do this and still have the problem I would contact Triton Customer care.
Thank you Ross.Welcome to the forum @Bob M
