Here's a link to the owner's manual for the TRC001.
https://www.tritontools.com/Helpers...nstructionManual&size=&name=556754_Manual.pdf
Be sure the spring has been removed from the plunge mechanism per the instructions. You may need to drill a hole in your insert plate for the winding stem to go through. But even if you only adjust from underneath, it should be easy if the spring is removed.
Don't scrap that one. I'll give you $50 for it, sight unseen.
