Welcome to the forum.
The reason is that my TRC001 is in need of repair but I can’t find a parts diagram for this model which I need to identify the correct part number. Also I need to know if there is a parts supplier here in the US.Welcome to the forum @Wisedm
I have a TRA001 and TRB001, and there is not much difference.
Minor changes to the plunge lock mechanism?
I had in the back of my mind, that the main difference was in the HP power rating. One is HP and one in Watts? 3 1/4hp -v- 2000watts?
What is the reason for the question?
I found this website helpful for parts. I got mine in 3 days in the USThe reason is that my TRC001 is in need of repair but I can’t find a parts diagram for this model which I need to identify the correct part number. Also I need to know if there is a parts supplier here in the US.
Thank you Old55 and jw2170 for the welcomeWelcome to the forum, @khannauman6
Hi, could you tell me how you modified your router for obove the table lift adjustment? Cheers LeeI found this website helpful for parts. I got mine in 3 days in the US
toolsparesonline.com/default.aspx
TRC and TRA are most likely same except a few new parts but the basic design is same in my knowledge. I was even able to modify my router to add the over the table lift mechanism which was initially missing in the older model.
