I use shop cabinets to try new ideas before using them on something more important. I'm making a small wall cabinet to fill an empty space and tried a couple of new (to me anyway) ideas.
- the cabinet was made at the total depth of the body and door and I needed some easy way to attach the face of the door. I clamped a piece of 2x4 (after running the one edge through the TS to give me a square edge) and used that to support the router while I ran a rabbeting bit along the edge.
- I cut a 5/8" radius on the corner of the plywood panel to match the rabbet, glued and nailed the panel in place and covered it with some 3/4" wide trim.
- I tried something different to cut the cabinet apart into body and door (I've cut opposing sides before, hot glued plywood strips to hold the cabinet together, cut the other sides and knocked off the plywood strips) and thought that I'd try something different as this was a relatively small (18" W x 24" H) cabinet. I set the height of the blade just under the thickness of the plywood and cut all sides, leaving basically the face ply intact, and then finished the cut with a hand saw. This worked very well, all I had to do was knock off the ragged edge with a Surform plane and finish with a sanding block.
This turned out to be a good way to add the door face without losing any additional inside depth and having to cut a dado to accept the plywood - I plan to use the same method to add the backs to the two cabinets going under my adjustable height workbench. One minor change will be to run the piece of 2x4 through the jointer first to take out any twist so it's easier to get it clamped up even to the face of the cabinet.
