I've made a loom for making twined rag rugs for daughter (see below). It has a couple of braces on the sides to hold the frame at angles for access during weaving. I made the braces with 1/4+" holes for 1/4-20 hardware.
But now want to modify this arrangement to make the adjustment positions slots rather than holes. And I probably want the openings of the slots to be wider than the bottom.
I'm wondering what is the best way to open these up. Do a full width plunge with a 1/4" router bit, using a miter gauge to impart a little bit of angle and flipping it around to give the other side some angle? Or bandsaw out the middle and do the above as cleanup passes with the router bit on both sides?
Nominally, I would do the latter, because bandsawing is easy and to minimize the amount of cutting the router bit has to do. But, sometimes, cutting tools like to have nice full bites. Also, I'm thinking the free-hand/miter gauge router passes may be easier to control taking just a little bit.
Thanks,
Rick
Thanks,
Rick
