Two More Done..
2381 Views 20 Replies 12 Participants Last post by  JFPNCM
Here's another two of the four or five I did last weekend. I have a couple I'm itchin' to get at with the router, but I have to do some sizing of the wood, first.
Ken had a hard time with the paint bleeding. They can still be sold, are going into the "For Sale" Bin, and hopefully, I can get out to the shed next weekend to do some cutting. Didn't get out there this weekend; yesterday was a busy day, and today we didn't get home till almost six o'clock. (That's a post for another day, which I will share later in the week... ) This whole week is gonna be a busy one for us. (Again, a post for another day, that I will share later this week)
But here's a couple I played with last weekend, and Ken (as usual) did my paint and poly.
1 - 20 of 21 Posts
Barb,
What kind of paint are you using?
We've used 2x cover Rust-oleum primer paint and the other was fusion flat black by Krylon. These two are new to us. We've also used Marsh Ink. Ken says he's still trying to find the right one for us. He's been watching You Tube this Winter, and wanting to try what others have said work well. Personally, I think Ken and I both got over zealous and forgot to sand the wood with a high grit sandpaper to make the paint come off easier. We had this problem before a long time ago. We cured it by sanding with like 220 or so, then used wood conditioner, so the wood wouldn't be so porous, but I think we forgot a step here, or we didn't let the wood conditioner dry long enough before he painted it.
He also used the oil-based varathane spar urethane, but was really disappointed with it. It left the wood feeling rubbery; didn't feel right, and didn't give the shine he was expecting. He said he's going back to the Helmsman high gloss that we've used for so long.
Hi Barb, the welcome sign with heart /fish hooks is my favorite.I reckon you could sell a bundle of those. James.
Marsh ink looks exactly like sprayed ink. Plus it bleeds all over the place. I don't like it at all.
I bought a case and have 3 or 4 cans left I think. Use acrylic paint. Most any will do. The spray stuff is expensive but Wal Mart has bottles of it really cheap. 1/2 the price of Michael's. You'll have to brush it but to me the extra time is worth it, and you get pretty good at it after a while. Less mess, less bleeding, and the excess sands off pretty good. $2 and change for 8 oz. Water clean up.
Reactions: 2
Nicely done Barb.
I will give you a 10 on those, I like the fish hooks too the best. Keep them coming, Love your work.
Hi Barb,
I like the both signs. Very nice work keep them coming.
Graham
I've used that paint for a long time. Takes too long to sit there and paint everything. I'm looking to cut time on my signs John. But thanks for the recommendation.
Thank you, James, Graham, Herb and Ross. Not my best... especially with the paint issue Ken had, but hopefully the weather will break, and we can actually get out there and figure out the best routine for us to kick these out quickly, with some quality to go with them.
Reactions: 2
Those two are very nice, Barb. A friend, Eric Rhoten, has been carving signs for about 30+ years. He sprays his with sanding sealer before carving. For inset carving, he uses the spray black primers or Marsh ink without bleeding. Then sands with a 40 grit belt sander, then 50 and, finally 80. Depending, he may use an ROS at 220.
If you haven't seen his You Tube videos, here's his channel. https://m.youtube.com/user/oldave100
Barb,
What kind of CNC are you using?
Don
Jim just beat me to it Barb. you can be honest with me, you used a CNC router didn't you?
Didn't know they had spray acrylic. I use oil paint when I paint metal, otherwise all I use is acrylic, works well for me, love the water cleanup, and smells better than oil paint. Don't paint so much anymore, but found out if you thin the acrylic, a lot, and paint it on wood it shows the grain nicely, and if you spend time in mixing colors, you can wind up with cheap wood looking like expensive wood. Last well also. Those times I do paint, I seldom use the stock colors, usually mix some custom colors, even if it is only a hair from the stock colors. I get the small metal cans in black, white, red, yellow, dark blue, dark green, and those colors will let me come up with any color, or shade (or close enough), that I want/need. I did try to mix some orange one time, but no matter how many times I tried, all I could come up with were various shades of pink. Never could figure out how that happened, I know how to mix for orange, and even consulted color wheels, and anything else I could think of. And still came up with pink. Finally just said to Hell with it, and bought a spray can of orange.
The acrylic makes an excellent fabric paint by the way, and cheaper than regular fabric paint. When my younger son was still at home, painted my initial on the pocket of all my T-shirts, so I could tell which were mine - no initial his.
I think you figured out the problem of bleeding when you said you didn't let the wood conditioner dry before painting. Normally wood conditioner is used to make stain less blotchy and most conditioners tell you to put the conditioner on then stain while still wet. The conditioner soaks into the end grain and softer parts of the wood and keeps too much stain from soaking in. If the conditioner is allowed to dry it will seal the grain and help prevent the paint from bleeding as bad.
Some people cut the sign, add the finish, then paint and add another coat of finish to seal. Using acrylic paint you can just wipe off and paint slopped over outside the lettering with a damp cloth as you paint.
Signs look good Barb.
Skill
Barb,
Did you learn how to make those signs freehand by just practice or did you take some type of training?
Don
I know all about Eric and his dad, Gene. Found their site years ago, and follow his videos. Some of their techniques don't work for me, unfortunately. That's why we tried the Marsh Ink, and the black primers; because I watched Eric and Dave use it, and figured we would try it. Eric and I have emailed back and forth a few times; we're friends on facebook. Eric, Dave, and the whole family are really good people.
As for the belt sander, for whatever reason, it gouges my wood; Ken can't get an even sand out of the belt sander, and the sander is new. the edge creates gouges. Ken and I both watch and have followed many of his videos, I've seen how he does his signs from beginning to end :grin: . I've watched as he's found new techniques for transferring patterns, different techniques, tricks, etc. In his last transfer video (for inkjet, if I remember correctly) I told him that was a lot of work to get to the process, and told him again about the Wintergreen Oil, and sent him my video on how to use it. I love watching their videos. Ken does all the sanding, painting, and poly work on the signs. I do the creating and cutting.
As for the Sanding Sealer, he (Eric) uses that on his pine pieces soon as he purchases the wood to help prevent cupping. Sanding sealer has done nothing for my cedar boards except to aggravate Ken. Haven't gone out and replenished my pine wood supply yet to see what it does. Eric also uses their cut outs for their patterns; he places them, then uses the paint to get his lines. I use my printer, and transfer my entire pattern. His way, I would be constantly buying cutouts, because they get gunked up, or many layers of paint on them. Then you have to buy more. Using my printer and wintergreen oil is more cost effective for me. :wink:
Barb,
Don
Don, I don't use a CNC. I freehand cut all my signs. I create my patterns on my laptop, reverse the image, transfer it to the wood, then cut them with my router.
I've been asked to make a video, and I've promised to do it, but I don't have anyone to record me from start to finish. I can record how I make my patterns, but no one to tape me cutting. :'(
No lessons. I've been blessed to be able to follow a line with my router. Back around 2000 maybe, (Ken reminds me) that my friend drew out a Scooby Doo on a piece of wood, and I took a router, and cut it. That was my first time using a router. I've basically practiced at what I cut, and learned from people like oldave100 on youtube for techniques on cutting. My friends here have been my lifeline quite a few times in my quest for router knowledge. They tell me I've started something with making my signs... another thing to be added to the list of things I'm blamed for :lol: :grin: :haha:
Harry, you're too sweet. You of all people can see the boo boo's in these :lol: Plus, you know my reply to CNC... that's cheating :lol::haha: Besides: I have no idea how to use a CNC. I wouldn't be able to find the start button.
Little known medical fact: CNCs can cause cooties.
1 - 20 of 21 Posts
