Hello........
I am new here.......just want to say thanks to everybody here for sharing....
I simply love woodworking......
and my english is a little rusty this days.....
I have a makita rp2301 plunge router.......and mostly use whiteside router bits.......
A few days ago while I was doing the joinery of an octagon to make a round table top......I had an accident and broke an expensive whiteside upcut spiral bit (ru5200)......it is a 2.5 long.....1/2 diameter Carbide Bit ......
It was my mistake.......
I was making a complementary curved joinery following a template with a guide bushing.......
but instead of cutting with a bandsaw the excess wood and routing a lighter cut following the template..........
I did the full deep cut thinking that the router would be more stable ......(routing 1/8 deep passes and cleaning the sawdust between passes).......cutting a groove with a W shape....
and in one of those deep curved cuts.......the bit grabbed the side and snapped badly......and loudly....
The problem now is.......that after the accident........
when using another very long (5.5 overall lenght) whiteside 1073-01 bit....
the bit tip´wobbles a little......and the router vibrates.....
the collet seems ok......
my question is.....
should I buy another router........and learn the lesson?
l
thank you
my question is.....
thank you
