Good day all,
I want to thank you guys for the tips on leveling the mounting plate on my Bosch RA 1180 table. Turned out fine.
Next problem: Whenever I run some wood through to clean up the edges, the cross section of the wood comes out looking like a trapezoid. After closer inspection, I discovered the fence-to-table junction was not at 90 degrees. No wonder! It appears to be off by several degrees. I edge jointed a 5/8" thick strip of wood. the upper side of the cut edge was about 1/16" loger than the lower edge of the board. Is this acceptable edge routing?
I emailed Bosch "Performance/design/safety" department with my findings. The person who answered me did sympathize with me and sent a new fence. After assembly, once again, I have the same results. I emailed them again, with what I thought would be useful information about their product. You know, a revelation of some sort. Their reply was less than enthusiastic. One of their tech reps insists that this is "normal." They claim this table's top is not supposed to be flat. A covex or concave difference of .040" is designed into the table. They also claim "If you're wanting to make squared cuts on this table, it isn't going to happen."
What should I, as a consumer, think about this? Accept the fact that my wife spent $200 on an item that doesn't perform the basic functions any router table and fence assembly should? In your opinion, is this an acceptable response from them or acceptable product? Are my expectations too high?
Thanks for the input,
Woodendigits
Woodendigits
