Hi Joe
Quote from MLCS Web Site ▼
SOLID CARBIDE BITS
Spiral Upcut and Downcut Bits
2 flute flat bottom cutters. Top quality micrograin solid carbide.
Will cut faster, smoother and stays sharper longer.
Produces a very clean, fast and accurate cut with minimal chatter.
Upcut spiral helps remove material. Ideal for making mortise and tenon joints.
Downcut spirals help hold the material in place while using handheld routers.
Will plunge cut and plane edges.
Eliminates chipping at the top of the cut. Ideal for soft & hard woods, plywoods & composites,
laminates, plastics and some non-ferrous metals.
Item #5155 will cut grooves for #20 biscuits. Item #7468 can be used with the Leigh Jig. Item #5161 can be used for inlay routing. item #5150/#5170 can be used for shelf pin router jigs
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_solid.html
Bj
