When you get ready to get a table mounted router, give serious attention to the Triton TRA001, which is a 3.25 hp machine with a built in lift. The cost is about $270 or so. It is really a plunge router, but you remove the return spring and it allows you to use a supplied crank handle to adjust the bit height from above the table. It also has great safety features. When you raise the bit to change it, it locks the router OFF so you won't have it start up when you don't expect it. You lower the bit and turn the switch back on for use.
Price on Amazon is $270. The 1617 runs from $200-$220. A lift will cost anywhere from $100 for the Router Raizer to $340 for the Jessem top of the line model.
Here's a pix, and you can see it in use on YouTube by looking up videos by Marc Sommerfeld. Be aware that for video, most will remove safety devices. But Marc's methods are really simple and direct and with safety covers and feather boards in place, they work well.
I've come to see that a tall vertical fence is one of the more useful things you can add to a table, whatever the router model. Clamp on or fixed, a tall fence lets you use simple techniques to cut tall pieces such as the ends of stiles for a panel door.
Pix of the Router Raizer 100 (W/DeWalt router) and Master Lift II attached. There are other brands and models close to $450. Whatever lift you choose, make certain you get the model made for your router, and the same applies to choosing the mounting plate.
