A bit of an odd use case but I'd appreciate any insights. I need to inlay holes 20mm wide and just 2mm deep into the end (the cross cut) of soft dowelling circa 25-30mm wide. Currently I use a quick vise, drill press and 20mm Forstner bit to do this, but it takes a lot of time lining things up.
I'm curious if I can use a router table for this, and simply (using a right angled jig) "drop" the dowelling vertically onto a bottom cleaning bit, thereby achieving the same thing? I imagine given it's only a 2mm depth, kickback won't be too material, and in any case the jig will provide some resistance?
I need to do a lot of these and hence I'm looking for a more efficient method than a drill press. Thanks very much for any insights that you have.
