1 - 12 of 12 Posts
This introductory "hello" will also convey my dilema. I have been planning a project to install European (hidden) hinges on all kitchen cabinets. I have also wanted to get a router for a while so thought I would combine the two objectives and use the plunge router to make the holes for the hinges, as I have 62 to install. A Forstner bit came with the box of hinges, but the 3/8" shaft won't fit my new Rigid router. The collet takes either 1/2" or 1/4" but nothing between. My question(s): is a Forstner bit not intended for use with a router? If it is, can I not get a collet adapter for 3/8" similar to the 1/4" adapter? The salesman at Home Depot (where it was purchased) said no. The widest straight cut router bit I've seen is only 3/4" and I need 35mm or 1-3/8" Any advice?
Steve, Forstner bits are definatly not for use in a router, these bits are designed to bore at a much slower speed than a router can produce. You would only manage to burn the bit very fast.
Discussion Starter · #3 ·
Thanks Jimmie. I guess I'll have to find a template or jig to use with my drill for the hinges... and plan some other projects for my new router.
G'day Steve
Welcome to the router forum.
Thank you for joining us
Hi Steve, Good to see you here. Hope you get all your questions answerwed..
Steve welcome to the RouterForums. Glad to have you join us.
Discussion Starter · #12 ·
Using Forstner bit with router
Welcome to the forums. You could always get a small table top drill press to use the forsnter bit in.
Thanks but Ive ordered a hidden hinge router template, as I'm more interested in using my router than my Forstner bit. I did one door with the Forstner and a cordless hand drill using a template I made for the job. It worked out OK but a router template with the plunge router will be much faster and safer (avoiding too deep a hole) and will give me a chance to get familiar with the router. I read a few reviews of the router template on line. One reviewer claimed to make 75 holes in an hour. Sounds pretty efficient to me. Thanks for all your helpful posts.
1 - 12 of 12 Posts
