How large of a radius are you thinking about? From the picture it looks like it might be a 2 1/2"-3" radius.
Maybe a bit like this, take a lot of passes of 1/8" height til you reach max.
https://www.amazon.com/Router-EnPoi...517805&sr=8-18&keywords=round+nose+router+bit
I would use a table set up, set it to start at the center of board and cut 1/8" high. Then move the fence away to cut max width,( W/O changing height. Then turn end for end and run it through to cut the other side. Then raise the bit 1/8", move the fence forward 1/8", make a pass then end for end do the same , repeat til you as deep as you want.
Or take it to the TS and draw the profile on the oend of the board and set your fence and blade height the cut to the profile and it will be a stairstep halfmoon cut when you are done and you can sand out the stairstep the make a smooth radius.
