I keep seeing Bob and Rick reaching down and turning the vacuum on and off, are a lot of you doing that?
The reason I ask is that sometime ago I picked up what was called a power tap at a Sears hardware store. It has Craftsman on the front and is gray. I have one on my computer system to turn on and off printers/scanner/etc when I turn the computer on, and another for my router table.
On the router table I have a power strip into which I plug the power tap. The power tap has two accessory and one power tool outlet. I put a short dropcord in to the power tool plug and the router gets plugged into the end of the drop cord. In one of the accessory plugs I plug in the vacuum.
When the power is turned on the router the vacuum automaticly turns on (the power switch on the vacuum is left in the on position). Now I spend more time thinking about what I'm doing with the router and less about did I or didn't turn on the vacuum.
Anyone else have a system like this? Any other sources of this sort of power tap?
Ed
Ed
