1 - 10 of 10 Posts
Discussion Starter #1
Hi folks.
Does anyone know where I can get a variable speed controller for a router? I have 2 fixed speed routers and for the type of work I have done, fixed speed routers have worked fine. Now I want to use a large router bit and the speed of my routers is way too fast and I need to slow the routers down for safety reasons.
I can get a controller kit that I have to put together my self but I would then need to buy a soldering iron to put it together, and maybe other bits and pieces too, which would make the whole thing too expensive.
Anyone know where I can get a ready assembled speed controller for a router?
Discussion Starter #3
Oooops
I forgot to mention that the controller needs to be for 240 volt routers.
Thanks neiltsubota for your quick reply, sorry I was not more specific.
Not as smart as I say I am. :no::fie:
NEW Router Variable Speed Control Box 220-240 VOLT UK EUROPEAN VOLTAGE NEW | eBay
NEW 220--240 VOLT ROUTER SPEED CONTROL BOX
Great for routing tough woods, plastics and even aluminum
Plug your router into this control unit & you instantly have a variable speed tool!
Works with any universal AC/CD brush type motor
8 AMPS & under
Input Voltage 220-240 volt capacity
Features: Variable speed or full run
Dim: 4-3/8" L x 2-9/16" W x 2-3/4" H
A must have for every workshop
I'm not sure if a conversion plug would work like it does on other electronics but if it would you can get a speed controller at Harbor Freight for very little money.
Hi Art
The HF or the MLCS ones will not work on the 220 volt setup. :(
Discussion Starter #7
Thanks to all
Thanks everyone.
And thanks to bobj3. That is what I am after. The guy who sells them is away and wont be back until early June so I will get one then.
Alex
You're Welcome Alex
They are very hard to find you may want to buy more than one and sale the others off to pay for yours.. (hint) :)
Thanks everyone.
Alex
1 - 10 of 10 Posts
