Veranda Railing
3K views 7 replies 4 participants last post by  jbrukardt
Good day - I am planning on adding a short section of railing at the end of our veranda to keep the dogs from leaping off and into the garden. I have the stiles - they are turned with a bit of character to them. I want to dress the top rail a bit and am looking for suggestions on the best bit to use. I plan on using 2x4 clear pine stock. The house itself is an 1870s Ontario farm house with a covered veranda on three sides.
I was thinking of the Lee Valley Tool Window Sill bit which would give a fancy finish, but may be too fussy. But other suggestions would be appreciated.
Cheers
Veranda Update
DaninVan: Attached is a photo of the house to give you an idea of the style. The bit that I want to block off is on the left had side at the back - not in the photo. I will try and get a shot of the stiles later today.
Cheers
Wow! It's in beautiful condition!! Has it been completely remodelled/restored?
Just a thought, but is there a Historical Society in your area? They might have archived photos of homes of similar style and vintage; it'd be interesting to see what they were using as handrailing back then, in your region.
So many Homes from the late 1800's were brick or stone faced in Ont. and Quebec. It's sort of an oddity with the lap-siding. I actually prefer it, and the white is classic. Lovely home, Peter.
Cheers,
-Dan
The style of your house is very similar to mine, even down to the unrailed porch. I recently put a rail completely around mine, and used a fairly gentle tabletop edge bit on the edge of 3 inch wide stock to create a nice look. It leaves a good amount of flat in the middle, and just "smoothes" the appearance. Take a look at any fancy table or dresser in your home and see if you like the look, i find it works surprisingly well for railings
