Which tool. If it's a router, which router? What bit specifically? Need more info.Hi All
I would like to know what causes vibration sometimes when cutting the end of the wood and how to avoid it
Thanks for the information
Stuart
lack of feather boards...Gentlemen thanks for the come back.
I'm Practicing to make raised panel shutters and sometimes I get a shutter in the wood when I cut the ends of the rails no problem with the stiles my bits are new.
Stuart
not the TS...Is it the workpiece that's vibrating a little up and down as it passes the blade? Or the saw itself vibrating? The first is more like chatter. Check the blade, tooth by tooth, any broken, chipped or out of line. Is the board twisted slightly (laying on the flat table, it rocks slightly side to side), or otherwise not straight and flat, then that could cause a problem.
