Viking Mountain bushing set from WalMart?
1603 Views 5 Replies 5 Participants Last post by  JeremySullivan
Good morning!
I just introduced myself in the introductions area, and I have a question: has anyone used these "Big Horn 19604" brass bushings from the Walmart website? It says "Sold and shipped by Viking Mountain Tool Works"
(I would post the link but I need 10 posts under my belt first.)
It's just brass, threads, and in circle form - shouldn't be too hard to produce, so is this at the level of a "Harbor Freight Gem"?
Thanks for any insight you may have!
Jeremy
1 - 6 of 6 Posts
Have never used those but, the price is right. Worth a gamble, I'd say. Their return policy is good.
Check for a short shank set, they allow you to use a thinner template. But this looks like a pretty standard set and the price is OK. Short shank means that the tube the bit passes through (collar) is less than a quarter inch long. Also, you must get a centering pin or cone (https://www.homedepot.com/p/Bosch-R...zA&gclsrc=ds&dclid=CMqc_9Ks7d0CFfMA-QAdoAoB7w) to make certain the bit is dead centered theough the collar. If it isn't it can affect the size or accuracy of the cut. Centering pins are cheap. Pix below.
Here's a video on how they're set up...
Reactions: 2
Viking is the outfit I bought my Musclechuck from and it’s a quality tool.
Thanks for the input everyone (and the links)!
-Jeremy
1 - 6 of 6 Posts
