Picture frame of the triplet grandsons (age 7)*
I used some Walnut I had laying around and added some Maple splines - used my
spline jig to cut in the corners (turned out a bit to thick (covering an error;-)
Sanding - 80, 120, 150 then 220 grit all around (I stop at 120 on the*back of frame)
prior to applying the finish I wet a*rag w/water and wipe down the wood - doing
that seems to raise the*grain a bit and then do a final 400 grit sand.
Finishing: my take on the "Sam Maloof type" finish
1/3 Boiled Linseed Oil
1/3 Wipe on Poly
1/3 paint thinner
SOP is to rag on the finish, let is sit for a few minutes, then wipe off the first coat or two
and after an hour*I wet/dry sand paper.*
Then 2 more coats get ragged on and wiped off without the sanding.
after 1 day dry time I then apply Johnson's paste wax.*
1/3 Wipe on Poly
1/3 paint thinner
