Weathered fence wood
1.6K views 6 replies 5 participants last post by  papawd
Hello ! this is my first post with a question. I want to make cedar fence wood look weathered and grey. I am thinking of using swimming pool Chlorine & water (strong solution) on the surface. Has anyone tried this? Thanks.
Hi Bob, I have had some success using sulphuric acid (drain unblocker) and then wash this off with amonia - best done in a plastic plasterers bath as the acid will not affect the plastic - oh and use gloves, mask etc as it does burn skin very quickly. Hope this helps
OK Thanks! I may try that. Might also try Muratic acid but I am trying to get weathered wood for some antiqued picture frames, rough look. I'm tired of prying old boards off of my fence. I am a little afraid of using too much acid around my pictures that I want to frame. Pool Chlorine seems to be working after about an hour and two applications brushed on. Now trying soaking for a while to see how that works. I think I can soak out the Chlorine pretty easy after I am done with this strong solution. Since it is too clod for swimming, I can just place them in the pool for a little while to remove excess Chlorine. :)
Hi Bob. Welcome to the forum.
Welcome Bob, I like the pool idea and if it seems to be working go with it Good luck
