First you need something to cut. In this case we have a 1 x 12 x 24 piece of glued up baltic birch from Menards on sale for less than $5.
Then we need something to make. Using Aspire we can resize some panels which are included in the clipart, and make a crescent moon with a couple round overlapping panels, saving the part we want (thanx MEBCWD). Text is added from the available fonts included with Aspire.
We save the file in our machine's code of choice, line it up, turn it on, and make some dust.
After it's cut we saw the connecting tabs off, pop our pieces out, do a little sanding and then finish as desired. Once the file is created and saved you can make as many as you want, and resize the model with a couple clicks of the mouse however you want. Here we made two separate cuts (less than $10 in material) and left one natural, used honey stain on the other, and then applied 3 coats of polyurethane.
Now, if an old, dumb, stubborn retired truck driver who hates new electronic stuff can do this then just think what you smart people can do.
