What Gauge Bolts For Jigs
3K views 12 replies 10 participants last post by  JOAT
What gauge hex and carriage bolts do you typically use for your woodworking jigs. Not heavy duty construction connections. More like the stuff for hold downs, slot and T track type attachments. I've seen design instructions that use 3/8" bolts but based on strength charts 1/4" would have been strong enough. Is it the appearance of more strength?
1/4" is usually good enough and usually cheaper because of being so plentiful but as Pat says, it can be application dependent. Rarely is strength that much of an issue.
Reactions: roxanne562001
Grade 5 or 8 wouldn't be necessary unless you are going to be putting a lot of torque or stress on the bolt. My Incra T-track uses plain ol' 1/4-20 hex head cap screws (full thread). I got mine at Ace Hardware as I get bonus $$$ for spending $$$ there. Actually, Ace has the best selection of fasteners, etc. in hardware than anyone else here unless you go to a fastener distributor.
#13 ·
I don't think I have ever used anything but Titebond II in making jigs. Certainly don't recall any with anything else. Never had any issues with any jig made with it. However, if I don't need a jig anymore, and want to salvage some of the wood for something else, it takes some serious pounding, with a 5lb hammer, before they come apart, and it's always the wood that parts, not the glue line.
