"What is it?" #25
2746 Views 14 Replies 7 Participants Last post by  reible
I'm not real happy with this next picture but I think someone will still figure out what it is and tell us about it..... if not I add some hints later. So be the first to tell us how this works and what it is for and you get 100 points.....
Good luck!
Ed
1 - 15 of 15 Posts
sluggo said:
It is a plug cutter
More details please.... What is it used for, why would someone own one...... you know details.
Ed
I think it is a plug cutter to cut a plug for a hole to match the type of wood that you are using. For example if you cant find a dowel of the same wood to match it.
Almost perfect Mike. This type of plug cutter actually has a slight taper built into it to assure a good fit. You are right about using it to make plugs, either matching or contrasting.
Mike was this your first post? It looks like to me so let me say welcome!
Winner
Yes that is the detail(s) we are looking for. One hundred points are coming your way, good job.
Ed
Thank you for your addition! I bought a set of these but I seem to use the one size a lot more then anyother..... I was thinking of upgrading at least that size, anyone have a brand or catalog spot with something of an upgrade?
I'll give 50 points to the first one who guess correctly what size is the one I've worn out..... and an extra 25 points if you know the "A" number.
I really like to see good follow up so keep it up!
Ed
Ed
The size you would have used the most is the 3/8" plug cutter, as this is the one used with #8 screws. Couldn't find any reference to "A" numbers, so will have to pass on that one.
Brian
Brian
Yes that is the size! I don't even know if they ever use the "A" number anymore but just in case this comes up........ No. 6A as in 6/16" = 3/8"......
Well you got the 50 points anyway...... now any thoughts about an upgrade/new style/new material????????
Ed
Ed, I dont think anyone has made a different cutter with a marked improvement over what you have. This is one of the first projects my 14 year old son jumped in to help me with; he cut the 140 plugs used for building the porch swing I posted in the Gallery. He was a big help when it came time for assembly too. It's good to know that there is life beyond Nintendo!
Sluggo, I'll give you 100 points for being first to answer
OK then, I'll just pick up one of these somewhere..... Thanks for the input!
I'm really glad your son was willing to "help"! I hope you two can keep it going, woodworking can be a great hobby or for some a great job. I'll check out the gallery again and look at the plugs.....
Ed
Thanks for the welcome. That was my first post. I have been reading the forum since the first part of december and really enjoy it. I am new to using a router as i got my first one for christmas (still trying to learn to use it actually). Thanks for the great info posted on the site
Now that you're in to posting when you have some questions just find the proper forum heading and ask. Most people here are more then happy to share. Do you happen to get the router workshop on your PBS station? If so make sure you check them out.....
Ed
1 - 15 of 15 Posts
