Thickness Gauge:
Useful for determining if another pass is needed while surface planning with your thicknesser.
Get quick readings of board thickness in 1/32" increments. The thickness gauge can measure boards up to 2" thick in 1/32" increments. Index stops set slightly larger than ¼" to allow for finish sanding.reible said:
Since I like us to learn as much as we can from these posts I will send 50 points to the first post the correctly tells me about the holes along the scale....... hey let's make that 100 points.....
I take it you own one of these? You are correct!Snowshoe said:Get quick readings of board thickness in 1/32" increments. The thickness gauge can measure boards up to 2" thick in 1/32" increments. Index stops set slightly larger than ¼" to allow for finish sanding.
Not yet, but again -- it's on my "next time I see one of those I'll grab it" list.reible said:I take it you own one of these? You are correct!
Ed
