Hi all. This concerns a Ridgid miter saw.
I usually cut miters by rotating the base of my saw, rather than tilting the blade. Today, however, I needed to cut the other way. I found that when I tilt the blade at 45 degrees to the base, it no longer cuts square to the fence. It's unusable. Here's are some pics illustrating the problem:
https://i.imgur.com/tGSTGvZ.png
Thinking it through, the only explanation I can see is that the pivot for the saw armature is not square to the base of the saw. Maybe it's tilted slightly toward the base, which would cause the blade to swipe crookedly across the wood when it's tilted, but still cut square when vertical. As you can see in the above pic, if I rotate the base about 1.5° counter-clockwise, it more or less corrects the error at 45°.
https://i.imgur.com/xfFpC3Z.png
Can anyone weigh in on this situation?
Thanks!
Thanks!
