Well, today, I got a Bosch Ogee 3 1/2" Raised Panel bit, thinking that would be perfect to go along with the Bosch Ogee Rail and Stile Bits I already have and have tried and succeeded making frames with. But, nooooooo, the opening in my Sears Craftsman router table is too small. I know I will have to take this Bosch bit back tomorrow.
The question is, what size should I get and what brand and will it work with the bits I already have as far as fitting inside the groove that my Rail and Stile bits make?
Should I get the bit that makes a groove in the back of the panel at the same time it makes the raised panel on the front?
Am I stuck with using the Ogee style raised panel bits?
Should I get the vertical bit and make the fence that Bj made for that purpose?
Thank you for your help, as always.
