hi all i used to work for a company that produced sheet metal parts for the aircraft industry, they used to rout parts using hss bit that ran either round the outside or inside of template to produce a replica of template.
i have 2 starter sets of bits in 1/4 &1/2 inch shanks but do not seem to have a bit for reproducing templates.
if i wish to cut an appeture right through a piece of 19mm mdf which i am using to get used to use of router, the only bit i seem to have is straight 1/4 dia X1inch the rest are mainly bottom bearing bits for edge work.
i am unsure wether to purchase a top bearing straight cutter that can be used to follow a template inside or out ,using plunge router or inverted in table,???
or is there something else straight /2 fluted/spiral/upcut, have looked at trend/rutlands tool bit catalogue more confused than ever
thank you
thank you
