I want to know what bit will cut a beaded corner on a table leg with a 1/8" step (i.e., inset) into the bead and a 1/4" radius on the bead? That is what is called for in the design I am following. The tech support at Rocklers suggest I use their #91505 beading cutter (1/4" radius, 1/2" height) and replace the standard 3/8" diameter bearing with a 1/4" diameter bearing. I suppose that will work, but is there a standard cutter that will do the job without modifying it?
I have looked at the list of Freud beading bits, but I don't know enough about the terminology to know if one of them will work - for example, they list the bearing diameter but not the small cutting diameter - maybe I can deduce it from something else. I need a course in bit terminology 101.
