Which router bit do I need to create this profile (see attached photo and description)? I have several bathroom vanity drawer fronts that need replacing.
Thanks in advance!!!
That's called a 1/4" bead and quarter round. A roundover doesn't produce the lip at the bearing.Which router bit do I need to create this profile (see attached photo and description)? I have several bathroom vanity drawer fronts that need replacing.
I like the bits where you can change out the bearings to get different profiles. such as the bead bits mentioned.That's called a 1/4" bead and quarter round. A roundover doesn't produce the lip at the bearing.
I love them, too. I've had to order hard to find special sizes to get the necessary profile I needed to match multi-bit profile cuts. They make the job a lot easier and safer than fiddling with a fence.I like the bits where you can change out the bearings to get different profiles. such as the bead bits mentioned.
