Afternoon,
I need some help with my routing process.
I make the large nativity scenes you see in the yards at Christmas. I use a pattern and then rough trim the ply to about 1/4 inch overhang to make the routing easier. Then I use a straight 2 flute flush trim router bit to follow the pattern.
Here is my issue. This takes time to do.
So here is my question. Can I invest in the router bit I included in the pic and not have to trim the wood to 1/4”? I am using the 3.5 HP triton as well.
Or another solution?
The bit is the Whiteside UDC 9112 if the picture does not come through.
Thank you.
Thank you.
