widest blade for a bandsaw?
1286 Views 5 Replies 5 Participants Last post by  DesertRatTom
I have a 10" Craftsman (Model 119.214000) bandsaw. It takes 70.5" long blades. I'm wondering what the widest blade I could use on it would be. There's nothing in the owner's manual. The wheels are1/2" wide, so I'm thinking that's probably the answer, but I wanted some other sources. I need to resaw some oak.
Thanks!
1 - 6 of 6 Posts
Realistically a 3/8" blade is about the most that saw can properly tension. A 1/2" blade may 'fit' but likely can't be tensioned properly.
I have a similar saw, but a little larger that can handle a 1/2 inch blade, but I'd suggest the 3/8ths as well.
Here's a chart of maximum radious curves to blade width. Below that is a stone I use to round that back of the blade so it turns more easily.
Font Parallel Circle Slope Rectangle
Wood Musical instrument accessory Hardwood Font Rectangle
I have the Rikon 10" band saw. I use the 1/2" woodslicer blade to resaw with. 1/2" is the widest blade that can be used on this size saw.
I have made blades, using 1/4", and 1/2" material- 2-3TPI blade stock.
All sizes have worked well.
I just purchased a 100' roll of 1/2" 3-TPI blade stock from Victor Machinery $78+shipping.
They have many widths and tooth configurations to choose from, if you want to make your own.
There are weld kits available, commercially.
Braise not weld. No heat treating or annealing required.
Just offering some options.
I just made a blade for my Jet 18" bandsaw using the 1/2" material. The blade is 150". I just re sawed 14- 15" wide boards that were 19" long. The blade is still sharp and ready for more!
Wood Watch Machine tool Gas Drilling
I have a similar saw (214.21400) and have successfully used 1/2" 3 TPI blades for resawing. I use Timber Wolf blades because they tension better and don't break as often as other brands I tried.
Reactions: 3
I use half inch Timber Wolfs on my little Rikon saw and they work well. Tensioning is the key to doing resaw work. I can resaw a 5 inch thick piece, but it is mighty slow going and there's some plane work to do after, so allow for that extra bit of thickness you're going to scrape off.
Interior design Wood Building Gas Machine
1 - 6 of 6 Posts
