21 - 27 of 27 Posts
· Registered
I always like to trade....always like to sell
Here is southern Louisiana we get a lot of humility in the air and therefore it is a necessity to keep my shop well insulated and the humidility as low as possible. With previous shops I had in the past fighting rust was always a problem and I had to have dehunidilityfiers plugged in more so than not.
Good insulation in my shop now has solved the problem and I never have rust anywhere. I does not get too cold here so I rarely have to use heat.
· Registered
Discussion Starter · #22 · (Edited)
We are about 2 hours north of Toronto Ontario. Not far from Owensound area.
Cold winters, good amount of snow, freezing rain at times with January, February thaws. Can get really damp and cool here in spring and fall. Summers can be humid and sticky.
Its never easy to plan or prepare for at times when we get hit hard at times as well.
We will have to take all weather patterns into account when building the shed for a small woodworking shop.
A dehumidifier sounds like a good item to have during these times. We are defiantly going insulate in order to have A/C for summer. Heat for early spring, winter, and fall months.
So many decisions to make but we will get it figured everything out eventually.
Learning what is needed is part of the fun and excitement.
The floor in our tiny 1 car garage is usually wet most of the winter since we park our vehicle inside. Although, I do squeegee the floor often, it does feel damp and cold at most times throughout spring, summer and fall . I can't afford to take the chance on having these tools rust so we made some space inside the house for these tools until spring.
· Registered
You rarely have to use heat? ever? Winter either?? Gee whiz, would you trade Januarys and Februarys ? I've never been that far south in central U.S. but I did see it on a map once. Do you know Bill ? He lives not too far from you. He's in Houston.
· Registered
Woodenhearted , With a garage like that why don't you turn it into a swimming pool ? All kidding aside, pay close attention to the surrounding dampness. It does a lousy job on tools. Will you be doing any of your work in the basement ? The worst part in a basement is dust control. A decent dehumidifier and good dust control can usually keep things in order. You don't need it desert-dry but you do need to keep the humidity down. With dust under control in the basement the only other thing you need be concerned with is noise but with Mrs. on-side you're way ahead of the game. Is your property in a low area ?
You don't need a tremendous amount of dedicated space to have a shop in the basement but I would say you need to have as many pieces on wheels as you can have. What kind of work do you intend to do ?
· Registered
To the group at large: In the responses I've just read, it was satisfying to at last get an idea of where some people are and how they function in their particular area, whether it be climate restrictions, sourcing material or tools or local bylaws etc.
Personally, I feel I have a better insight into member's goals, challenges, and even personalities when I can form a mental picture of someone and their environment. I know it's not a "guy" thing to get too warm and fuzzy but I think we can relate to someone's problem, be it material or tools acting up or whatever when we have a bigger picture. I still haven't heard from anyone in Australia that can tell me how they do so much while upside down.
· Registered
Discussion Starter · #26 ·
Hello Thomas,
We were planning on putting these tools in the basement, setting up a proper dust control unit etc. That was our plan until plans changed.
Our daughter needed to move back home with the 2 kiddies last spring. This has altered our plans since she will need to stay for a couple more years yet.
My garage is terrible really, I have a slanted driveway with a drain in front of the garage door in which I have to use a submersible pump to get the water out prior to coming into the garage. Therefor the spring melting and heavy downpours of rain usually floods our garage.
We have been planning to fix this for a couple years now lol. Other things just seem to come up, well, along with the renovated basement apartment that we finished last spring.
We have a contractor coming to look at it next week to see if they can fix it up properly.
As for the type of work we would like to do,
We are just going into this as a hobby, making a few signs, some pine corner shelving, and possibly a new wall unit for our daughter.
I do feel quite lucky that my wife is very supportive of this adventure and has no issues when it comes time to purchasing the tools necessary. We stay on track together and communicate prior to any purchases, this stays in line with our monthly budget for this hobby.
We are looking forward to getting started in the coming weeks and sharing things that we are learning and trying to do as we go along.
· Registered
Discussion Starter · #27 · (Edited)
Did fill in the hole that caved in on the 1 side of that catch basin.
I just finished it yesterday. Temporary fix until the contractors come out to have a look.
It took the good out of me since I haven't done anything that labor intense all winter.
A few trips to physio therapy has already been booked for the ache muscles and bones haha.
Road surface Asphalt Grey Tar Manhole
Tire Wheel Vehicle registration plate Car Vehicle
Road surface Asphalt Building material Gas Road
Blue Selling Public space Wall Gas
We also need better retaining walls on both sides of the driveway. Need to remove the rocks and flower garden as well to keep the runoff at a minimum to the drain from taking too much water at once. If it's even possible.
We should know next week.
Here is a few pictures of the mess we are currently facing . Tools are in the house for now.
Water Road surface Asphalt Floor Flooring
21 - 27 of 27 Posts
