I know this question has been asked before but I continue to struggle with filling pores on open grain woods. Specifically, Walnut, Purpleheart and Mahogany. The closest that I have come to acceptable is to put down a base of dilute Sealcoat. Then three coats of Crystalac, a water base grain filler that dries clear, and sanding between coats. Then multiple coats of wipe on Poly. As I said, it’s a lot better than nothing but still isn’t completely smooth.
I watched a number of YouTube videos then searched on Amazon for “wood grain filler”. Although there were a lot of products listed few had high customer ratings. Even the ones touted in the videos received low customer grades. I’ve even tried multiple topcoats and sanding back until the surface was smooth. Since it was Poly, that didn’t go well either as I ended up sanding through the coats and creating rings.
I know that I’ve got to be missing something. Has anyone had good success with any product? If so, exactly how did you use it? As always, I appreciate any help you can give me. I really need it as my frustration level soars when I mess up a nice piece because I don't know how to finish it correctly.
