1 - 14 of 14 Posts
· Registered
I made this post to let people know about Multiple Layer Inlay Stencils that help you create wood inlays with your router that really add something special to your woodworking projects.
I currently work with my Dad who is a much more seasoned woodworker than I am,
designing wood inlay templates for woodworkers from beginner to pro.
He had already started creating an entire set of letters and numbers because he wanted to inlay my sons name into a bookshelf and simply couldn't find a good set of templates when he asked me to join him.
Here's the results of the numbers and letters using the templates...
Heres the templates...called Multiple Layer Inlay Stencils(MLIS)that are used to make the inlays.
As you can see...
The underlying idea is that you need multiple layers in the templates to achieve sharper corners and to have a more intricate design. We soon found that there is a lot you can do with multiple layers...
The clear plates with the design engraved on them definitely allows you to visualize the finished inlay better, and lasts much longer than an MDF template.
We also discovered that there are certain things you should do to make sure you finish with a tight inlay with virtually no gaps to fill. We found the ideal double sided tape to hold the templates in place as well as the ideal inlay kits. We made positioning plates to make placement and replacement of plates quick and simple...
We have many more designs we are planning to release in January but would love to get feedback and suggestions from router woodworkers who are looking for templates that help them inlay what they want.
Please leave feedback here and submit ideas to the contact us page to help us make the Multiple Layer Inlay Stencils you want and will enjoy making.
visit tarterwoodworking.com to see more and what's new.
Thank You,
Larry Tarter Jr.
P.S. Our designs seem complex to the naked eye even though they are easy enough for me(someone who never used a router in woodworking before) to create the lion that you will find in the art section as my first inlay! So... we made a video and put it in the how to section to make it simple to understand.
I would post links but I'm new to router forums.com
· Registered
Hey, Larry; those are brilliant!
There was a thread here a little while back, about making hearts, and the inability of being ably to make the sharply defined 'V' at the top. Looks like you and your dad may have solved that type of issue(?).
I do believe the sign carving folks will be lining up.
Be careful with your posts though, the moderators are adamant about not allowing commercial self-linking in the comments.
(Personally, I sort of wish the rule was a biiiiit looser.... :) )
· Registered
Great idea Larry - this is hard to do trying to get layers to match when cutting the patterns out of wood. Do your layers fit inside a jig or do you have to spot each one by markers?
What type of double sided tape do you recommend? Ive tried many and it is hard to find ones that have the holding power and dont leave any residue.
Dennis
· Registered
Discussion Starter · #6 ·
Dennis
Dennis,
We use 2" thick double sided tape that is 9mil thick instead of the thinner strips. There is masking tape that works well with holding the wood together without movement. The clear works good for holding the acrylic templates in place as well as holding the wood. Sometimes there is a very minor amount of residue when you pull off the tape... but very little that gets sanded off easily anyways.
Tip: when applying the tape, and peeling the backing off, put the tape on the template or project wood, then use your finger or a putty knife and hard press the tape onto your finger or the putty knife and twist. Then the backing is easy to peel off.
Also, I use positioning plates to hold the templates in place during the process of using multiple plates to make them easier to align consistently.
· Registered
Discussion Starter · #8 ·
Question: With multiple layers like this doesn't it reduce significantly the depth you can rout to, or are the perspex layers thin enough for this not to be a problem?
Cheers
Paul
Good Question. The multiple layers give you the ability to create the complex design. You actually only use the router with one template stacked at a time. Each plate is about .22" thick so you can use any router inlay kit that has a bushing depth of less than that. For example: You would place the first plate into place, and rout out the pocket and press in the inlay. Then move to the next template plate in the set and do the same thing. Continue until you have walked through the creation of the design.
Check out an in depth video of the process here: How to create a wood inlay using a Multiple Layer Inlay Stencil (M.L.I.S.) or Router Inlay Template
· Registered
Thank you for your response, but I think you will see from the lack of all other responses that this is a 'help your mate' type of site , rather than a means of getting links to your commercial site. This was obviously your first intent, as the moderators will maybe have picked up, as you objected in your first posts as to not being able to post url links before 10 posts.
I wish you success in your endevours and thank you for you input so far.
But leave out the links to your own sales site.
Paul
· Registered
Discussion Starter · #10 ·
Paul, Just trying to help answer your question. I thought that the video would make it clearer for you to understand what I meant. I realize that this is a help site. If anyone wants to know about router inlays than I can definitely help, but sometimes it takes a link to a video to do so. Good luck with your future projects!
Larry
· Registered
As you can see...
Thank You,
Larry Tarter Jr.
Totally love the positioning plates, It makes alignment so much easier. Finished your Bonsai Tree inlay on a gift charcuterie board. it turned out perfect. So looking forward to new ideas for multi-layered inlays
· Official Greeter
Welcome to the forum, @sundog422
This is a vey old post, so you may not get a response..
The OP has not been on site since 2015.
1 - 14 of 14 Posts
