This is the Rob Corson dowel hinge.
With a bullnose or ball router bit on a router table the size of the dowel, route a 1/4 round slot in the back of lid and back of box. Set the fence at the center of the bit diameter and run the top and the box through. The fence can be set in or out to suit the particular box and how wide the lid opens.
Take a dowel the same size as the router bit and cut lengths to suit the length of the box, they can be the same length or different lengths. Drill a hole in the center of the dowel the size of the pin. The pin can be metal rod, or wooden dowels.
Assemble the dowels on the rod, and adjust to the length of the box,marking the positions of the dowel segments on the box and the top.
Put a little glue on every other segment on the box. MAKE SURE THE GLUE HAS ROOM TO SQUEEZE OUT AND NOT SQUEEZE INTO THE NEXT DOWEL SPACE. Carefully lay the assembled dowel hinge onto the glue. Carefully set the top on and lightly clamp down
When the glue is dry lift off the top and spin the every other dowel. Then apply a small amount of glue onto the free spinning segments of dowels allowing for squeeze out of the glue. carefully set the top on and clamp lightly. Allow the glue to dry.
After the glue has set, gently open the box. The Joy you feel when the box opens is beyond description, the sinking feeling if it doesn't is beyond printing. Only had one that didn't open, and I have done a lot of them.
You can also wax the pin,if you so desire.
