1 - 5 of 5 Posts
· Registered
Very Good Condition, lightly used, must sacrifice!
$225 plus shipping or best offer.
Willing to accept personal checks if you are willing to wait several days to assure clearing bank!
1472 Angle-Ease is designed for the PC 7518, Milwaukee 5625 (w/optional 1430S Shim) or 3-1/2" motors from the Bosch 1617 & 1618, DeWalt 616 & 618 and Porter Cable 690 & 892 (w/optional 1425R1 Adapter). The Angle-Ease allows your router to do things no other tool can do. It's safer then tilting your work, and multiple profiles are possible with just one bit. Combine its angling ability with a few common router bits and you can duplicate moldings of all kinds! Angle vertical panel bits, or other style bits, to produce unique one-of-a-kind moldings. With the Angle-Ease, you are only limited by your imagination! The Angle-Ease is designed for router table use and features a 9-1/4"x 11-3/4"x 3/8" phenolic plate. Includes height adjuster with a 2-1/4" fine adjustment. Height or angle settings controlled with knobs, no tools required during operation. Positive stops every 5º;, plus 22-1/2º;. Scale has 1º; markings. Some assembly required.
1472 Angle-Ease is designed for the PC 7518, Milwaukee 5625 (w/optional 1430S Shim) or 3-1/2" motors from the Bosch 1617 & 1618, DeWalt 616 & 618 and Porter Cable 690 & 892 (w/optional 1425R1 Adapter). Bosch Shim included!
Allows your router to do things no other tool can do.
Safer then tilting your work.
Combine with a few common router bits to duplicate moldings of all kinds!
Router, bit and router table not included.
· Registered
· Registered
Welcome to the forum. @Gracie1945 hasn't been here in 3 years.
Interesting product, what projects do you have in mind for it? Looks reasonable to build your own, or a jig to hold your work piece at an angle for use on a table router.
1 - 5 of 5 Posts
