aniceone2hold said:Herb, the Woodrat is a specialized machine for making dovetails and other joints.
Click this link to learn more: http://woodrat.com/
Unisaw said:WOW. That sucker is expensive! $650 US. I choked when I bought my Leigh.
Dewy said:I havent used one but know they are held in very high regard by those who use them and others just drool over the ease with whitch joints can be made with one.
There is always a lot of good natured banter between rat owners and non rat owners on the UKworkshop forum http://www.ukworkshop.co.uk/forums/
If you do decide to buy one make sure you buy enough cutters at the same time although I presume with Woodrats inroads into the USA market the cutters will be as available in USA as in UK.
The woodrat, or its smaller brother the little rat, use HSS cutters for a much cleaner finish than with TCT cutters.
You will notice that the Woodrat takes up very little space in the workshop as it mounts to the wall at the height most comfortable for you to work at without having to bend down.
