1 - 20 of 59 Posts
· Super Moderator
Well, I have finished building the cabinets for my BIL, and a few projects around our house so now is the time to rebuild my work bench.
As some of you know, I am in a one car garage which has a lot of stuff in it. :frown: Not much working space, but I seem to manage some how.
So here is my plan. It may or may not end up that way, but this is my thinking.
  • Build a Ron Paulk inspired work table.
  • Use drawer/tray features Earl Davidson used in his build.
  • Demo the top part of the existing bench and re-frame it 11 inches lower.
  • Use the lower portion (including the three drawers currently in use). No need to modify them.
  • Drill dog holes on 4 inch centers.
  • ??Use the Kreg Klamp Track if possible?? Maybe, maybe not.
I bought the plywood and have it cut to size (36 x 60 inches). That's as big as I can go and still be able to re-position my power tools as needed.
I am using 3/4 inch for the top and 19/32 for the bottom. I think that is about 5/8 inch thick. I hope to mount a paper roll bracket on one end and the table extension currently mounted on the work bench on the other end. By doing that, I don't see any need to cut out the waste. That would just take up time. Same goes for the two supports under the top...just leave them solid.
I have a tentative pattern laid out, and just returned from Rockler with a 1/4 inch spiral upcut router bit. The sawdust slinging will commence shortly!:surprise::grin:
I will post some pics as I go along. The last picture in this post is my current lay out. The new top will be about 3 inches wider front to back and about 11 inches longer.
Here are some links where I got my inspiration.
Ron Paulk Compact Work Bench
Jay Bates - Modified Paulk Work Bench
Earl Davidson - Modified Paulk Work Bench
· Registered
Nothing on TV last night so I watched a couple of these movies. The last one was interesting, I noticed that you plan to put the drawers under your workbench as he did. That really looks like a good idea, although one has to wonder how often they have to be cleaned of all the sawdust, etc. that falls in there. If I didn't have all the money tied up in the Kreg legs and the hard maple butcher block top, that may be something that I'd consider doing.
On your holes, are they strictly for clamping access or were you planning to use then for track alignment as Festool does with their MFT tops. I ran across this the other day UJK Technology Parf Guide System - Circular Saw Accessories - Sawing - Power Tool Accessories - Accessories | Axminster Tools & Machinery - from the rave reviews, it seems to be a very nice set-up for making your own top, very well thought out system in that the layout sticks are also used to assure that the series of holes are perpendicular to each other which would be needed if you're going to use them along with the dogs to set a fence square to the track. I was looking at the Festool replacement tops and thinking that would be the way to go if you were building your own as the Parf system seems a little pricey for a one-time use.
Lee Valley has a bushing to make your own jig for drilling the dog holes Dog Hole Bushings and Bits - Lee Valley Tools although the cost of their drill bit seems a little high as I've seen others cheaper although the question may be whether they're long enough to go through the jig and the top.
As far as the clamps, there was a discussion on the clamps a while back - one option for a thick top would be use the HF clamp, remove the head and attach the short piece of flat bar through the pin hole and use that to catch the underside of the bench. It would be easier than having the end of the clamp fall on the drawer every time as was happening in the movie.
· Super Moderator
Discussion Starter · #5 · (Edited)
Thanks. I made a small jig and did some practicing on my existing table top. Even though I was diligent in laying out the holes and reference holes, somewhere along the line they got off just a tad. It doesn't have to be much. It probably happened when I marked the spot to drill and then positioned the piece under the bit on the drill press. That is where a CNC produced template would shine. Maybe I just can't do it manually.
So, the answer to your question is no to the parf dog style system. But having them for clamping purposes will be great. I already have been using the clamps we modified and they are working great. I will definitely be going back to my buddies house with another handful of clamps and the rest of my rod. Short ones this time. That is what I use most. $2.99 at HF! :surprise: You just can't go wrong with those clamps.
For those with thicker tables, Jay Bates showed what he did. He ground off the brad on the lower end, then sticks the clamp shaft into the hole from the top and reaches under the table, reattaches the clamp piece and sticks a nail through the hole, making the clamp hole again. I did notice in a later video, he decided to go a different route and made a modification to an Irwin quick clamp basically doing the same thing as I did. He cut part of the shaft off and reattached it with 45 deg miter cuts and some welding. I like my idea better than both of those.
My current table has holes but sawdust hasn't bothered me. I have lost a few screws over the years but I retrieved them last week. My top is so heavy, it just sits on top of the frame. I managed to lift and scoot it over and there were the screws and a Bosch knob that holds the dust port on the router! I wondered what happened to that thing. :surprise::smile:
In his video, Earl said he cut some 3/4 inch dogs and plugged an area where he does most of his work. If he needs a dog, he reaches under and pushes it up.
· Super Moderator
Discussion Starter · #6 ·
I have all the pieces cut out, milled and ready for assembly. It took all weekend but I got it done.
Using a track saw, I cut 2 36 x 60 inch pieces for the top and bottom. One sheet is 19/32 and the other is 3/4 inch BC Sanded Pine.
Next I cut to length the two sides 9 1/2 x 60 inches. Then I cut 2 pieces for the ends and two middle supports. That worked out to be 9 1/2 x 34 5/8 inches. Since the plywood is two different sizes, that means the back side piece will be slightly narrower than the 3/4 inch thick front piece. That's OK by me.
Saturday, I made a template out of mdf, and sure enough, I screwed it up. After all the careful planning and lay out, when it came time to cut it with the router, I cut the rounded portion square. That was a temporary set back that added two hours to the day! :frown: To repair it, I fabricated a couple of corner pieces with the correct radius and edge glued them in place. And they are still stuck. :surprise:
That brings us to today. With the template in place (via screws), I commenced to cutting out the waste portion of the openings by using a 1/4 inch spiral upcut router bit and a 1/2 inch guide bushing. Obviously, that leaves a lip so I set up my trusty old 80's model 1 HP Craftsman router with a flush trim bit and cut the lip away. That makes two routers in action. :smile:
You might notice some dog holes in the sides and ends. There is room so I set up the templates and cut 'em out with a 1/2 inch spiral upcut bit in a 3/4 inch bushing. That made for a snug fitting 3/4 inch hole. Three routers in action! :surprise:
With all the holes and openings cut, I rounded all the edges slightly with a 1/8th inch round-over bit in the little DeWalt router. Four routers in action today!
I drilled pocket holes in all of the pieces so I can attach them to the bottom. I have some 1 1/2 inch trim screws that I will use along with gobs of glue to assemble the frame and attach the top.
Note that I didn't cut any material from the ends or the inside supports. I don't see any need. And I hope to work in a kraft paper roll rack on one end and maybe reattach the table extension on the other. I will have to wait and see how that works out.
Now with all that said, I am having a blast building the table of my dreams...many dreams! :grin::grin::grin:
I hope to start assembly tomorrow.
So, with no little helpers around today, it was just me 'n the boys - all four of them! :surprise::grin:
· Super Moderator
Discussion Starter · #11 ·
I have and use the Parf guide sytem ; I find it it very straight forward to use.
Roger, it isn't the system. It is my lack of ability to create a template that is accurate enough so when I drill the holes, the parf dog system would work. :surprise::frown:
Note I am also drilling 3/4 inch holes also. Mainly because I already have money invested in several types of bench dogs.
· Super Moderator
Discussion Starter · #12 ·
· Registered
Mike,
I ran across this video showing the use of a drill (router) jig for boring the dog holes in a work top,
I follow what he's doing up to the point where he puts the center locating hole in the fixture as it looks as if it's just eyeballed relative to the grooves - maybe if the fixture is always aligned the same way for every hole, any error in location of the hole relative to the groove intersection is consistently off. Must be, because it looks as if he got the pattern pretty accurate.
· Super Moderator
Discussion Starter · #14 ·
Yeah, I have watched it a couple of times. Not for me. Too many opportunities to make an error and throw the whole thing off. At least it would be if I was doing it! :surprise::frown:
· Super Moderator
Discussion Starter · #15 ·
I had a good day today, and it ain't over yet! :grin:
Upon close inspection, I realized the openings didn't match. They were hand grenade close but not much else. So, first off, I screwed the two side pieces together. Then I got my router with the flush trim bit and ran it around all of the openings on both pieces. That resulted in perfectly matched openings. This is important because the tool trays will be accessible from both sides. Just push or pull them.
When I was finished, I used the router with the round over bit and eased the edges again. Looks much better and I am happy.
Before any assembly, I did a dry fit with most of the pieces. Lots of clamps. :surprise: It looked to me like I would have to do something with the two middle supports to make them pull tight with the front and rear side pieces. Well, Mikey, why don't you drill a few holes in them and use your recently modified Fe$tool style HF clamps to pull everything tight? :surprise::grin::grin::grin: OK. You can see in the pics there are three holes near the end of both of the middle supports. This worked great.
I started with the side piece that will eventually face me and my project builds. Glue and pocket screws attached it to the bottom. Lots of clamps held it square to the other pieces.
Then I attached one end, and then moved on to the two middle supports. My home made 90 right angle jigs helped keep everything square.
Finally, I turned the bench around so I could attach the remaining end and the back side piece. More glue and screws, and a little clean up. I didn't skimp on the glue. I also used some trim screws to attach the sides to the ends and middle support pieces.
And, BAM! just like that it is assembled!:smile: OK, the top isn't on yet, but you get the idea. One of the pictures shows the top resting on the structure. I am not quiet ready to attach it yet. I am still thinking about what else I want to do like a Moxon vise like Jay Bates built, either permanent or portable. And/ or what about the Kreg Klamp track on the old bench? I really like that thing. I've become really attached to it!
Here's today's pics.
More later.
· Registered
Looking good Mike, you're making me embarrassed about how little I got finished today.
On the Kreg track, wouldn't that require you to double up on the plywood top? And what would that do to your new clamps, would they still turn through the hole if the top was 1-1/2" thick?
· Super Moderator
Discussion Starter · #18 ·
I was thinking I would double up under the area where track would go with a little extra meat on the side. Looks like I would have to add it after I put the top on, or maybe do a dry fit and hold them in place with screws until I could turn it over and glue it good. Still thinking about it.
My helper is in the shop working hard. We have the top demoed, stripped of hardware and set aside. Dang I built a pretty solid bench a few years ago. It doesn't want to come apart! :surprise::grin:
· Registered
Rick
Mike are you going to install that bench vise on the end , as I really like that idea .
After seeing you get this project underway ,I'd love to undertake a build like this .
I sure like the storage area under the top
1 - 20 of 59 Posts
