Hi everyone, first post here. I have a DIY built cnc machine, been using it for 6 months now, it work great from the beginning but now noticing the z axis is not returning to zero when I send it home position, when I do a big job that requires a lot of up and down and many passes with a v bit carving the z axis drops more and more so when you send it back to home after a job the z axis drop quit a bit, I have check my motor coupler and set screws and they were tit. Is it possible that my z motor is not strong enough? I am using a
Nema23 23HS5628 4 Lead Nema 23 Stepper Motor 57 165 Oz-in 56mm 2.8A 6.35mm/8mm TB6600 CNC
Has anyone ever encounter this problem? Thanks for any suggestions!
