This box was inspired by a design I stumbled onto @ a site you would never expect to find such an example. (first photo) I didn't look for a copyright, so I might be in trouble!
The Zebrawood was given to me and I made several other similar designed boxes from different species of wood scraps, for practise. Here is my version as it turned out.
I have made a jig to fit my Veritas RT top, to do the 3.8" box joints. I am really happy with the tight fitting joints this jig provides. ( jig is made from hardwood flooring scraps) The contrasting wood, I think, is some Malaysian Mahogany. I was hoping it might turn out darker, but you take what you can find when the budget requires free stuff. I did make 3 different handles for the lid before I found the one I liked best. The only caution I have for others; is to do all your fine sanding to completion before you glue the legs and handle onto this box, and be very careful not to use excess glue (5 min. epoxy) so there will be NO squeeze out, doing legs and handle. Regular wood glue was used for box joints, with water clean-up and final sanding after. Clean-up is nearly impossible with so many contours. Any squeeze out will mess up your finishing if you don't get it cleaned up completely. I use Teak Oil on nearly everything I build. I used it here too. The final finish coats will be clear Varathane, semigloss, over the Teak Oil when it is completely dry and sanded again to remove any nibbs. I love doing all sorts of different small boxes. Hope you enjoy this contribution. More photos to follow.
