Beautiful and very modern. I'd never encountered Airicote before, so here's what I found on the web about it:
Ziricote is the most dramatic member of the Cordia genus and stands apart from other exotic woods due to it’s unique grain lines that frequently depict spider webbing, marbled swirls, cloud bursts, mountains, valleys and other captivating patterns. The heartwood is reddish brown with irregular chocolate or black streaks that tend to form abstract art within itself. These color tones contrast nicely with the sapwood which ranges from creamy vanilla to golden tan. Artisan craftsmen are fond of incorporating this sapwood into their projects to maximize the final visual impact. It is a stunning combination indeed!
With a density higher than rosewood, Ziricote turns very well. It is able to take a very smooth finish and a high polish. Ziricote is slightly brittle but also known as a good steam bending candidate and is proven to hold nails and screws well. This exotic hardwood is easy to work by hand or machine and is stable in use. Ziricote wood has a medium to fine texture and a straight to slightly interlocking grain. It has a tendency to develop end and surface checks during drying, but is stable afterwards. Quartersawn surfaces will sometimes display ray or flake patterns similar to Hard Maple. The highly figured spider web grain is similar to what can be found in Brazilian Rosewood only more complex. Surface has a natural waxy appearance and takes on a satin finish with simple sanding.
The picture is a particularly striking example.
