My router now has a mind of its own. I had a board move causing the 6mm EM to drive into the wood and break. I lifted the router, removed the bit set it to "go to zero". It did not. I had set the bottom left corner as the zero axis. It went to the middle then moved all the way to the left. i tried to run two more projects and both times in the middle of the run the router moved to an area not even in the gcode.
I use mach 3 with a chinese 6040 router. Any sugestions? Should I reset the software or have I messed up my axis points. Should I re-calibrate my router? If so is there any videos or help text to show me how to do this properly?
It was a good year, learned a lot, made a lot, and now have messed up a lot!
