Been using a zci(zero clearance insert) with a shop vac and have been getting a belly full of saw dust
Have used a peg board zci to allow the shop vac extra air to swallow the dust with no joy
Have used a solid zci with a large hole up front to allow air in & again no joy
also used a solid zci with just the slit for the blade---no joy
so-- 3 strikes--I'm out
it's obvious that the saw dust is being thrown from the back of the blade, over the wood & directly forward.
dust control with "standard" insert is ok
a large central vac is not an option
Am I expecting to much for a zci or is there a better solution?
thks
smitty
thks
smitty
