thanks Herb for the update..
Chuck,that is what they were originally sold for, but someone must have used them on the TS, and now they advertise them for such. I have in the past used masking tape and duct tape, but they don't hold up long and eventually will roll up and stick to the bottom of the cut and cause a problem.They're supposed to help with miter saw cuts too. I may have to pick some up.
it's 1/64''...There was a question by a member of another forum ,if it changes the angle of the cut to be raised up the thickness of the tape on the cut end. Tomorrow I will cut and fit some miters and check them for square. The tape measures .53mm not sure how many inches that is.
Bob,I was just about to ask the same question. To get accurate angles you would have to coat the entire table with it. Not necessarily blanket the table, but enough strips to keep the project level to the blade angle.
