Rockwell Bladerunner X2??? - Router Forums
 1Likes
post #1 of 13 (permalink) Old 12-17-2016, 06:48 AM Thread Starter
First Name: Ron
Default Rockwell Bladerunner X2???
Gents,
Recently relocated, sadly had to leave my bandsaw behind, looking for a substitute for small projects...saw the Rockwell Bladerunner X2 which is essentially an upside down jigsaw mounted under a plastic table, which MIGHT suffice for now.
Anyone out there have one/used one?
Thx in advance,
Ron
rpludwig is offline
post #2 of 13 (permalink) Old 12-17-2016, 07:11 AM
First Name: Steve
I bought one several years ago and mounted it on my shop wall. Vibrated so bad I couldn't use it to make exact cuts. Took it back for a refund and bought a good hand held jigsaw to get me by until I could afford a nice bandsaw.
Knot2square is online now
post #3 of 13 (permalink) Old 12-18-2016, 04:15 AM
TWheels's Avatar
I have one. It is indeed difficult to make a straight cut. There is a a "fence" to one sie and a miter gauge to the other so angle cuts are possible. Blade insertion is more of a nuisance than I expected, more so than any jig saw I've used. As @Knot2square said the vibration is bad. It is cheap and I would say you get what you pay for.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #4 of 13 (permalink) Old 12-18-2016, 06:37 AM
First Name: Ed
Not sure how much space you have maybe you could use a bench top band saw.
Price wise some of the cheaper ones are not much more then the blade runner.
herrwood is offline
post #5 of 13 (permalink) Old 12-18-2016, 06:43 AM
I've had one for a few years now. I use it for household jobs and not really for woodworking. It is great for small jobs that don't require a lot of precision. It is certainly not a long term substitute for a band saw. The best feature is the portability. It is lightweight and blade changes are a breeze. Doesn't create a lot of mess either.
Rick
RickPr is offline
post #6 of 13 (permalink) Old 12-18-2016, 10:35 AM
First Name: Ron
Purchased one a couple years ago, returned it the next day. Wouldn't cut straight, vibrated like crazy. Worthless for woodworking.
alaskagypsy is offline
post #7 of 13 (permalink) Old 12-18-2016, 01:51 PM
First Name: frank
Default Blade Runner
After reading the other previous posts, I guess I was the lucky one out to this group. I purchased mine a few years ago. It is the first edition. It has worked well for me. as for the vibration, I have not had that problem yet. I use mine often, not huge projects. It was never meant to be a band saw replacement. I do use it to cut small circle cuts, even up to 2 inch cuts. I have mine mounted on the wall with the hangar that came with it. I never have used it while mounted. I made a bench hold down for it and I just slide it into place. The new 2nd edition has some upgrades that look good to me. One is the saw hold down is now mounted in the center and the fence is a new addition as well. The price is much less now than when I purchased mine. Like I said it is designed only for smaller items. I think on mine ii try to cut anything wider than about 8 or 9 inches, I have to remove the arm.
At any rate, if used for what it was designed for it works great. I used it to cut all of my under ground watering system. One thing to remember is clean it up with forced air when finished. Normal moisture will cause the dust to settle around the blade insert. Keep it clean and like any other saw it wil do the job for what is made for.
Tagwatts is offline
post #8 of 13 (permalink) Old 12-18-2016, 10:38 PM
whimsofchaz's Avatar
First Name: Chuck
I have seen used band saws for less money on Craigslist
whimsofchaz is offline
post #9 of 13 (permalink) Old 12-19-2016, 03:31 AM Thread Starter
First Name: Ron
all good advice/reviews....gonna pass on this thing...will make do without for now, have a good jig saw, router table, table saw and be on the lookout for a decent used one...
Thx!
Ron
rpludwig is offline
post #10 of 13 (permalink) Old 12-19-2016, 12:28 PM
Not sure what your budget is for a band saw, but I recently replaced both my large and small bandsaws. Got a Fourteen/12 for wood prep, and a Rikon 10 inch for the shop. The Rikon was just under $300 and can be ordered from Amazon. I use the smaller saw in my workshop, the larger for wood prep (resawing in particular) and keep it in the garage.
That Rockwell has always gotten mediocre reviews, and the blades are easily bent. The Rikon 10 inch is a really nice little unit, I have found it to do what I've asked of it. It uses a 70 1/2 inch long blade (longer life than a 9 inch). and I got a premium half inch blade for it that allows for limited resawing (go SLOW). It has the steel frame, is very solid construction and easy to set up. And it has roller bearings and a rack and pinion blade guard. WEN also markets this same saw for about the same price, surely made in the same factory and also offered on Amazon. The reviews are pretty good on both saws (for the price) but if you get a ringer, Amazon is good on returns. I bought my Rikon at Woodcraft and it was the floor model. It had a damaged tension knob, but one call to Rikon and it was in the mail the next day.
Here's a pix...
Name:	Rikon 10 inch band saw.jpg
Rockwell router , 5372 / 350m Deadeye086 General Routing 4 07-28-2019 08:09 PM
My Brand New [Fifty Some Year Old] Rockwell Delta 46-450 Lathe Dejure Woodturning and Lathes 12 02-08-2018 12:22 PM
Manual needed Rockwell T100 Shaper JoeP148 Tools and Woodworking 5 10-06-2014 07:29 PM
Vintage Rockwell Delta DP (1951) floor model worth $200? Scratchndent Tools and Woodworking 15 08-15-2013 10:33 AM
Rockwell 4" Jointer 37-290 knife thickness. rwl7532 Tools and Woodworking 1 01-17-2012 01:10 PM
