Drum sander recommendation - Router Forums
 11Likes
post #1 of 21 (permalink) Old 09-29-2017, 10:59 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Default Drum sander recommendation
I've been relying on my neighbors good humor to use his drum sander for the last 2 years and while there is no problem therein, I think it is time to invest in my own. So, any recommendations will be appreciated.
I'm not looking for an industrial strength system but rather one under 20" for example the JET or Supermax models.
Thanks in advance for your comments.
Herb Stoops likes this.
Jon
JFPNCM is offline
post #2 of 21 (permalink) Old 09-29-2017, 11:49 PM
I have the Performax, which is now the Jet. Jet bought Performax and the old owners started the Supermax company, which makes a larger and improved model of the Jet.
This is my third one and I am totally happy with it, I have the 16/32. I had the 10/20 first, but outgrew it and went to the 16/32. and lost that one in the fire so replaced it with a new one before the jet came out, but it is identical to the jet. the Supermax 16/32, and 18/36 are suited for home shops,but the have a gaggle of larger models.
Can't go wrong with either brand.
Herb Stoops is offline
post #3 of 21 (permalink) Old 09-30-2017, 01:03 AM
JOAT's Avatar
First Name: Theo
I don't need one, but if I did, I'd take a shot at making my own.
https://hackaday.com/2014/12/27/diy-...a-guitar-shop/
kp91 likes this.
JOAT is offline
post #4 of 21 (permalink) Old 09-30-2017, 02:31 AM
Is this basically the same one?
https://www.kmstools.com/king-canada...-sander-106700
DaninVan is offline
post #5 of 21 (permalink) Old 09-30-2017, 06:52 AM
Stoneface's Avatar
First Name: Frank
I have the Performax 16/32. I bought it many years ago at an auction. I resaw a lot of Walnut and plane the boards to thickness. I then go to the drum sander to get final thickness. Usually this is the last sanding required. My unit has the variable speed feed rate, but newer models have a load/feed speed controller. If I ever upgrade, this would be a feature I would look for. I cannot comment on the quality since Performax was bought out. I have no issues with my old unit and would recommend it. Would be a interested in hearing others comments on newer models.
Frank
Stoneface is online now
post #6 of 21 (permalink) Old 09-30-2017, 07:38 AM
kp91's Avatar
First Name: Doug
Originally Posted by DaninVan View Post
Dan,
that looks just like my Ryobi, which was later made by Steel City
It is a little bit of a finicky machine to set up... which is why I got it so cheaply from the previous owner, who got it cheaply from the original owner...
Getting the table parallel to the drum, getting the tracking of the feed belt down were my biggest challenges. And these things are heavy and awkward to move around by yourself
Once it is set up it does a great job, but there was a day or two I thought I was going to give up on it.
Hopefully they've made some improvements to make the set up easier, because they are real time savers.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 21 (permalink) Old 09-30-2017, 07:59 AM
If I were going to get one, based on the feedback in posts in the past, I'd go for the SuperMax. Laguna just bought them out, and that company goes for the high quality tools.
MEBCWD and Herb Stoops like this.
post #8 of 21 (permalink) Old 09-30-2017, 08:58 AM
difalkner's Avatar
First Name: David
We bought the SuperMax 19-38 last year and it's a great machine. I wouldn't hesitate to buy another if we wear this one out.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #9 of 21 (permalink) Old 09-30-2017, 03:15 PM
Default Another clone?
This one looks identical, BUT if you look at the specs for the one I posted earlier, there are small differences. The one from KMS has a more powerful stock feed motor @ 1/8HP as opposed to the Craftex at 1/15HP
The one from KMS is also slightly less expensive during the sale.
Buy Drum Sander 16in. Open End Csa Cx Series at Busy Bee Tools
DaninVan is offline
post #10 of 21 (permalink) Old 09-30-2017, 04:18 PM
Frank the first 16-32 Performax I bought had the smart feature on the feed belt that regulated the feed rate with the power load on the sanding drum.If the motor load increased over 15 amps it slowed down the feed rate accordingly.
The one I have now I bought used in the carton off Craigs List and doesn't have that feature. So I had it set up with an ammeter digital readout mounted on the motor to show the power draw as I set the feed rate manually. when it reads 15a.-18a. I manually reduce the feed rate with the dial and keep the motor from heating and kicking out the over load button. With out any load on the motor it runs @10.5a.-11a.
If I am not paying attention and it goes up to 20a. then it kicks the overload button.
The newer Performax and the Supermax both have the smart feature built into them.
Drum Sander tracking problem kp91 Tools and Woodworking 5 05-24-2017 09:02 PM
question about V Drum Sander size Tom in indy Tools and Woodworking 3 03-09-2014 04:15 PM
Build Mobile base for a drum sander RickPr Tools and Woodworking 10 01-12-2013 09:15 AM
DS-1632 Drum Sander, Any Good. wm460 Tools and Woodworking 10 03-03-2012 03:28 AM
Drum sander help please? Birch Tools and Woodworking 6 04-19-2007 03:57 PM
