Table saw for diy projects - Router Forums
 15Likes
post #1 of 15 (permalink) Old 01-08-2018, 05:55 PM Thread Starter
Default Table saw for diy projects
I am looking for a table saw for some diy projects around the house. I have been considering the Ridgid heavy duty job site saw and the delta 6022. Does anyone have any comments on these saws or have another saw in the same price range they can recommend? Thanks
Sent from my iPhone using Tapatalk
beast1286 is offline
post #2 of 15 (permalink) Old 01-08-2018, 06:07 PM
Hey, Beast; welcome!
The Bosch TS has a lot of fans amongst the members that have them...
https://www.amazon.com/Bosch-Worksit...SIN=B000S5S5CW
Personally I have a 15 yr old Delta contractor saw, but new it's considerably more expensive.
Where you're posting from may have some bearing on cost to you; can you fill out something about yourself...completely voluntary of course, but it is a bit more helpful if the other members know where ypu're from and maybe a little about your experience level(?).
We welcome everyone of all levels but it's kind of pointless telling you something you've known for years
jj777746 and hawkeye10 like this.
DaninVan is online now
post #3 of 15 (permalink) Old 01-08-2018, 06:32 PM
move to the head of the class and get yourself a Bosch 4100...
far superior than what you are looking at and Bosch's CS/TS run circles around the the other outfit's CS/TS...
VOE....
old coasty and jj777746 like this.
post #4 of 15 (permalink) Old 01-08-2018, 10:29 PM
I have to add my vote to the Bosch column. A friend of mine expanded the table surface area by building a larger top with an opening into which the saw fits. He adjusted the saw height to precisely match the plywood surface height. He also added laminate to the top to make workpieces slide easily.
hawkeye10 likes this.
post #5 of 15 (permalink) Old 01-08-2018, 10:59 PM
Don't quite understand, Tom, the bosch 4100 has the expandable to the right table top with a flip of a lever, not sure how a cut out works.
I have the Bosch 4100 and it is a great little saw, I wanted a model to set on a base cabinet so took off the folding mobile stand to gain some room in the shop.
Herb Stoops is online now
post #6 of 15 (permalink) Old 01-08-2018, 11:25 PM
out-feed table...
DesertRatTom likes this.
post #7 of 15 (permalink) Old 01-09-2018, 01:10 AM
Welcome Beast. You didn't fill out your profile so I can't be sure exactly what your needs are or how much room you have. As good as the 4100 and maybe one or two other small saws are, there is a decent possibility you could pick up a good used saw on Craig's list for the same or less money. A friend of mine wanted to upgrade from his old Rockwell Beaver 10" saw to something newer. He offered it to me for $100. I took it. I already had a 90s model Unisaw but up till then I was using a cheap craftsman for a second saw. The Rockwell has either a 1 1/2 or 2hp motor compared to the 3hp my Unisaw has. I added an Accusquare after market fence to it and most of the time it will do almost anything the Unisaw will. So for under $400 you can get a saw that will cut circles around the 4100 or any saw like it. It may take some time but those deals are out there.
post #8 of 15 (permalink) Old 01-09-2018, 06:25 AM
Nickp's Avatar
First Name: Nick
Cannot beat Bosch 4100 for diy or jobsite...great fence, no need for aftermarket...make a crosscut sled for it and sleep comfortably...
Best success in your search...
old coasty and Herb Stoops like this.
Nick
Nickp is offline
post #9 of 15 (permalink) Old 01-09-2018, 06:52 AM
and it will handle a full dado blade set...
DaninVan, Gaffboat and Herb Stoops like this.
post #10 of 15 (permalink) Old 01-09-2018, 10:31 AM
Imagine a large table with two layers of top. the distance between the two tops is slightly more than the height of the saw. Now cut out an opening in the top layer just the same size as the saw. Shim the feet of the saw and place it in the opening. Now you have a large, stable top that serves as an extension and outfeed table. My friend had a 2x4 attached to the ceiling that extended down and held a dust collection port just above the blade. He did a lot of woodworking for his boat and liked the extra support of an extended table. Just mentioning it because it was a nice setup. He could still take it out of his shop if needed. It was his personal preference.
Herb Stoops likes this.
Another Newby Tweety New Member Introductions 13 12-18-2017 07:38 AM
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 11:30 AM
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 10:51 AM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-03-2009 12:34 AM
